Problem Error 11 - Motor protection parameter P9-01 or Small frequency converter selection
Results 1 to 4 of 4
Thread: Error 11 - Motor protection parameter P9-01 or Small frequency converter selection
    Member bescorza's Avatar
    Aug 2021
    Question Error 11 - Motor protection parameter P9-01 or Small frequency converter selection
    Hi there!
    I have a 3 axis CNC6090 with a 2.2 kw spindle.
    Recently, after a 5 hours strait operation, the spindle became to work as half energy and I immediately turn it off.
    After that, every attempt to run the spindle, the VFD pannel notified the "ERROR 13".
    With this situation, I looked after some youtube videos and try to find what was about. At the same time, I change some parameters in VFD and that was a big mistake.
    So, I decide to contact the factory (ChinaCNCzone or SCOTLE TECHNOLOGY). They gave me the path to reset all the parameters and recover the originals parameters. In addition, they explain to me that the "error 13" was a bad connection on the splindle cable or plugs.
    Well, checking the continuity, I found the problem. The cable no. 3 was interrupted.
    Problem solved
    But not! Now, my VFD is showing the "error 11". That means 2 options: Motor protection parameter P9-01 or Small frequency converter selection
    Is there someone that knows this parameters?
    HELP, PLEASE!
    Attached Thumbnails Attached Thumbnails Error 11 - Motor protection parameter P9-01 or Small frequency converter selection-whatsapp-image-2021-07-30-11-43-a   Error 11 - Motor protection parameter P9-01 or Small frequency converter selection-whatsapp-image-2021-07-30-11-43-a
    Member mactec54's Avatar
    Jan 2005
    Default Re: Error 11 - Motor protection parameter P9-01 or Small frequency converter selectio
    Quote Originally Posted by bescorza View Post
    Hi there!
    Problem solved
    HELP, PLEASE!
    Do you have the VFD Manual PDF post it here
    It sounds like you may have some spindle motor damage do you have a Ground / Earth wire on the spindle this must use a 4 wire shielded cable
    What is the name of the VFD Drive they are using
    Mactec54
    Aug 2021
    Thanks Mactec54 for your help!
    About de VFD Manual, I just found this topic: https://www.cnczone.com/forums/spind...gs-manual.html
    Unfortunately, this is not my VFD...
    About the wire, I'm using the 4 ways cable, stock, with that aviation plugs, also stock...
    Where can I find the drive? I'm asking this because my machine has a DSP controller.
    Jan 2005
    The DSP controller is not what runs your spindle there will be a VFD Drive inside the box
    There are many VFD Drives you can not just pick one you have to know what you have , yes it is not a Huanyang as the Parameters are not correct for that VFD Drive
    Mactec54
