It would work, but the VFD will be your weak link. A wiser choice would be a 10hp hitachi VFD. Some may call for the 15 hp. but that's overkill, IMHO.
I purchased a Jianken 5.5 kw (7.5 hp) spindle and would like opinions on which VFD to purchase for the unit. The spindle is 220v 14.6 amps. I only have 220v single phase available. Would I need to purchase a 15 hp VFD? Or would a 7.5 hp Hitachi P1-00330-LFUF be sufficient?
Thanks for all help.
- Need Help!- HY02D223B VFD with 2.2KW Watercooled Spindle GDZ-80-2.2A Spindle - External Controls
- Buying NEW VFD for 2.2KW Spindle (OLD VFD died)
- Need Help!- HELP ES100 VFD and 2.2KW spindle - SPINDLE RUNNING HOT/VFD ERROR!!!
- Need Help!- Mini Mill X2 Spindle Head + VFD + Chinese Spindle= custom!
- 2.2 kW spindle with Hitachi VFD or 3 kW spindle with Huanyang VFD
14.5 amps seems low for a 5.5Kw motor
The VFD Drive input rated Amps is the most important when using Single Phase for this 14.6 amps the VFD Drive input amps has to be no less than 27 Amps rated input amps, the supply would want to be 35 / 40 Amps this is right at the max spindle motor size for Single Phase use why did you go so big when you new you where going to run it on Single Phase
So you just can't guess the VFD Drive size buy a big drive is not always the answer
Mactec54
Really did not think through the VFD prior to purchasing the spindle. Should have gone with a 5 hp spindle, however if I can make it work with a 10 hp VFD I will do that.
Thanks Karl, but I have never been accused of being really smart, however sometimes things work out for the better and hopefully that is the case here.
Mactec54;
Sorry for late reply but it is a 2 pole 400Hz spindle. The Vfd that I am looking at can run in Sensorless Vector Mode. Which would be a wiser choice between these 2 drives?
P1-00460-LFUF
WJ200-075LF
Sensorless Vector is the best choice if it will work at up to the 400Hz a lot of Sensorless Vector drives don't function very well at the higher Hz rating and will not auto tune correctly, so you may have to fool the drive and temporary set to a lower Hz setting, ( Like 300Hz ) and then auto tune and then set it back to the 400Hz
The Sensorless Vector Drives will run the spindle a lot smoother normally and have a better overall performance
Mactec54
I run a 5.6kw / 7.5hp 24,000 rpm 220v 20a PDS 3ph spindle from a domestic 1ph 240v circuit. There's plenty of VFD options at various price points.
I use a Huanyang 7.5kw vfd designed for 220v 1ph in / 220v 3ph out. It works fine and I've been using it to mill aluminum at 24,000 rpm so I've not exactly been babying it.
My 240v circuit is 50a (which is plenty for my spindle).
There's a bunch of other generic Chinese variants on ebay too. E.g.
https://www.ebay.com/itm/22440760865...Cclp%3A2334524
There are also VFDs that can run 380v 3ph spindles from 240v 1ph outlet. And ones that go up to 1500hz.
If money is no object then you could just get one of the premium brand VFDs. They don't usually offer 1ph in that size so you'd have to double the size (so a 15hp 3ph vfd to run a 7.5hp 3ph spindle from a 1ph outlet).
