Reservoir size for 2.2kw spindle?
Results 1 to 2 of 2
Thread: Reservoir size for 2.2kw spindle?
    Nov 2016
    Default Reservoir size for 2.2kw spindle?
    I purchased an Jian-Ken JGL-80 water cooled spindle, 2.2kw with ATC. I'm setting up the pneumatics for it now, but will soon be moving to the pump and reservoir. Is there a recommended size of reservoir for 2.2kw spindles? This is for a hobby CNC and won't be seeing hour-long use cases. I'm thinking 20-30 minutes per cutting session max.
    Thanks!
    Dec 2017
    Default Re: Reservoir size for 2.2kw spindle?
