Need Help! Error E stop presset
Results 1 to 3 of 3
Thread: Error E stop presset
    Default Error E stop presset
    Please help.
    Router set up with Gecko 540, uc100 Huanjang vdf with 1.5 kW water-cooled spindle. Mach3 Version R3.043.062. Win 7.
    The router runs fine on all stepper motors. When the spindle starts, the machine runs for up to 6 sec. stops. Error message e-stop pressed.
    Dec 2003
    Default Re: Error E stop presset
    Sounds like you have a lack of grounding in crucial areas, do you have a star point ground system set up for a start?
    Is your Spindle frame grounded?
    In some cases the 4 pin socket on the router is missing the ground wire from socket to frame making the ground conductor inefective.
    Problem solved. Frequency converter fault
