Suggest Choose China 5.5kw cosntant water cooling spindle +water cooling system .
This type spindle is main for stone and aluminum .
Omni cnc stone router engraving and cutting Marable tombstone3
The boss purchased an Off-Brand 3 axis CNC router for our stone business. The spindle failed with very few hours of use. Seems like the bearings failed. The spindle has no NEMA rating, probably has too little torque, and we suspect it isn't built to handle the special rigors of cutting stone. We'd like to replace the spindle with a more robust, properly rated unit. I am attaching the spec for the defective spindle. Any help will be appreciated. Thanks in advance !
- spindle recommendation for cutting mild steel
- New Machine Build- 3 AXIS CNC STONE CUTTING MACHINE RC1325/ STONE ENGRAVING MACHINE
- Need Help!- Spindle/Motor recommendation for cutting HDPE tube
- Just IN- Water jet cutting machine for cutting glass stone metal
- Spindle+VDF recommendation for long jobs cutting 18mm Plywood below €1000
thank you, Mactec54
