Problem VFD Huayang EER.N error code
Results 1 to 2 of 2
Thread: VFD Huayang EER.N error code
    Member digifabb's Avatar
    Dec 2020
    Default VFD Huayang EER.N error code
    Model HY02D211B 110v driving 2.2KW spindle
    Error Codes:
    177 ELU.N
    178 EER.N
    179 EER.N
    180 EER.N
    Manual lists as "External Interference".
    Any suggestions will be appreciated.
    Question:
    Any suggestions?
    Does the error code reset on restart?
    Perhaps I have to change the 110v AC supply cable to a shielded cable?
    Other:
    The spindle drive cable is 2 feet and is 16 gauge, 4 conductor, shielded with both ends grounded.
    I also grounded pin 4 of the spindle drive to the spindle body and checked continuity to table ground and input power ground.
    I tried setting PD041 from default 8 to 5,2,1, and finally 0 with no effect.
    The error code appears without ever starting the spindle.
    I used this and other helpful links to set the VFD settings and wiring:
    https://www.hobbytronics.co.za/Conte...e_Settings.pdf
    Ref: https://community.carbide3d.com/t/vf...-model/15459/7
    https://www.cnczone.com/forums/spind...rror-eoca.html
    Member CitizenOfDreams's Avatar
    Nov 2012
    Default Re: VFD Huayang EER.N error code
    Edit: Never mind, I was thinking of a different error code.
