- abb vfd asc355 to setup brake
Hi, i try to install a vfd abb asc355 on a spindel 10hp 380v. I can run the motor but I not understand how to set-up the brake. i need to use resistor brake. i tied to put 2020 to 0 and 2005 to 2. but i not have brake fonction. the resistor i used is a 100ohm 200w. there are ther parameter to set?
Dominic Foisy
- You may not post replies
- You may not edit your posts
Forum Rules
