Huanyang GT series VFD speed control, UC300eth and uccnc
Results 1 to 2 of 2
Thread: Huanyang GT series VFD speed control, UC300eth and uccnc
    Sep 2014
    Default Huanyang GT series VFD speed control, UC300eth and uccnc
    Hey everyone,
    I'm setting up my VFD and spindle... both 2.2kw 220v and I have a question in regards to speed control. I tried looking for the answer without any luck... I'm able to control the speed with the potentiometer with the jumper installed on J1 1-2 but uccnc won't control the speed. If I remove the jumper from J1 obviously the potentiometer stops working but I can control the speed with uccnc. Is there a way to have both working simultaneously?
    Also, what can cause the VFD to not be able to control the spindle in vector mode?
    Member mactec54's Avatar
    Jan 2005
    Default Re: Huanyang GT series VFD speed control, UC300eth and uccnc
    Quote Originally Posted by frank_n View Post
    Hey everyone,
    The Vector control does not work for these High frequency spindles
    The J1 jumper should always be in one of the positions it should not be removed completely
    You can't have both, Pot ( manual ) control is when you use the Key pad, remote control the pot does not work although I found a way to make it work on a regular Huanyang VFD Drive I will check and see but normally you can't have both
    Mactec54
    Sep 2014
    Thanks for the info Mactec54...
    Explains why I couldn't get it to work with the vector control turned on.
    The J1 jumper had two jumpers installed... it's a 4 prong jumper. When I removed the top jumper that's when I was able to control the speed from uccnc but lost control from the potentiometer.
