look at emgprecision.com based in UK, ask for a 6 poled spindle, should handle steel but does not have as high rpm (i belive 8 or 12000 is max)
Sent fra min SM-G975F via Tapatalk
I'm looking for spindles capable of cutting steel but the ones I've found on amazon only work properly at rpms that are too high to cut steel properly. They work but badly. The issue is thy have to be at least 8000rpm to get access to any power... I've presumed that other companies solve this with a gear box but that solution would be a tedious for me and isn't ideal. Any ideas? I'm based in Ireland so it would be great if I didn't have to order from America or China. I'm not a fan of Alibaba, Aliexpress or even bangood due to bad experiences.
You haven't mentioned your price range, Hiteco has a full range of spindles and they are based in Italy, if you wanna save some $$ you can get some really good spindles or motorized spindles from CTB servo, That's chinese but you can buy directly from them.
Mactec54
Cheers guys, price range is around 300 Euro.
