Display RPMs
Results 1 to 6 of 6
Thread: Display RPMs
    Default Display RPMs
    Hello all
    I have a water cooled GDZ-100-4.5 spindle 220V 400Hz 24000rpm spindle and my VFD is a YL620-G-5.5Kw 220V. I have everything running as it should but need to change the disply to show RPMs instead of the frequency (which I think its currently displaying) I have tried pushing the display button (many times over) but it never changes anything. I am unable to get it to display RPMs. Attached is a picture of the display I have.
    I read somewhere people were potentially changing something in P00.24 but i have not had any luck with this either (attached are the manual pages discussing these settings.
    Any help would be greatly appreciated.
    Attached Thumbnails Attached Thumbnails Display RPMs-unnamed-1-jpg   Display RPMs-4-jpg   Display RPMs-5-jpg
    Default Re: Display RPMs
    Any one?
    Jan 2005
    Quote Originally Posted by lx450landcruiser View Post
    Hello all
    If you press the shift key until the red led is showing under the RPM then it should show what the RPM's the spindle is running at, no Parameters to change
    - - - Updated - - -
    Hello all
    Mactec54
    Hello again Mactec
    If you see the attached photo of my "interface" you can see it shows the DISP button is my shift key. No matter how many times I press this button the red LED lights above to not change to RPM. It actually does nothing at all.
    Jan 2005
    Hello again Mactec
    Try any of the key unless it is locked I will check the leds should change it normally is the Disp button but could be any of the buttons that change the mode it is in
    Mactec54
    Jan 2005
    I took a look at the manual and you may be able to change the parameters in
    P00.24=6 or 9 and see if you get any changes still may have to use the Disp key or any key that lights up the RPM led
    Mactec54
Display RPMs
Display RPMs
Display RPMs
