Desperately Need VFD help!
Results 1 to 3 of 3
Thread: Desperately Need VFD help!
    Member TF1618's Avatar
    Feb 2021
    Default Desperately Need VFD help!
    I am new to using a CNC. I have a CNCEST 6040, 4 axis, 1.5kw spindle. I reprogrammed the VFD values. Now the spindle will spin, but it is not moving on any of the axis. It doesn't matter if I'm using manual or computer. As I said I am new to this, Any and all help is appreciated.
    Dec 2003
    Default Re: Desperately Need VFD help!
    What motion (CNC) system is it running?
    How is it programmed G.M. code etc?
    You should be able to move the axis regardless of the spindle via a MDI move.
    Apr 2004
    Oakland CA USA
    Does it move if the spindle and VFD are turned off?
    Andrew Werby
    https://computersculpture.com/
