- Need Help!- Mitsubishi Fr-D720s
Mitsubishi Fr-D720s
NOTE FOR Moderator, Would you please remove the previous posting of mine on this thread. Many thanks
I need a littler help please. Mr moderator, if this is in the wrong section would you please move it to the correct section, thank you.
I screwed up my settings om my FR-D720 Mitsubishi Frequency drive.
I'm using a Chinese spindle motor 200730184245.5 rated at 8amps, 400Hz, 220V, 2pole,24,000RPM,
Can anyone remind me of the FR-D720 parameter settings for this motor. Please be aware I'm running the inverter in MON mode (Manual)
I cannot seem to get top speed of 24000 RPM any more. It's been working fine for over 10 years. I should not have played around with the settings, I did an All Clear function and a Factory reset function.
I have uploaded the documentation, I'm sure I had put the parameters back to where they were but it's still not right. If anyone can help I
My Parameters are set as follows:- If any one would like to compare these with those on page 54 & 56 of the manual I would be extremely grateful.
0 - 4
1 - 120
2 - 0
3 - 400
4 - 400
5 - 200
6 - 100
7 - 5
8 - 5
9 - 8
10 - 3
11 - 0.5
12 - 4
13 - 0.5
14 - 0
15 - 5
16 - 0.5
17 - 0
18 - 120
19 - 8888
20 - 50
22 - 150
23,24,25,26 & 27 - 9999
28 - 0
Keep safe and well all.
George
- You may not post replies
- You may not edit your posts
Forum Rules
