- Need Help!- FRD-700 and Chinese 1.5KW Chinese Spindle motor
I need a littler help please.
I screwed up my settings om my FR-D700 Mitsubishi Frequency drive.
I'm using a Chinese spindle motor 200730184245.5 rated at 8amps 400Hz 220V 2pole 24,000RPM,
Can anyone remind me of the FR-D700 parameter settings for this motor please.
Kind regards and hope you are all safe and well.
George
Re: FRD-700 and Chinese 1.5KW Chinese Spindle motor
I have managed to get my Spindle motor running again but it would be good if anyone can check my settings please. Here's what I have
Parameter Number followed by value set followed by descriptor
0=4 Torque boost
1=400Hz Max freq
2=0Hz Min freq
3=400Hz Base freq
4=400Hz Hi Speed freq
5=30Hz Mid Speed Freq
6=10Hz Lo Speed Freq
7=5 Accel Time
8=5 Decel Time
9=8 Motor rated Amps
10=3 Brake Freq
11=0.5 Brake op time
12=4 Brake op Voltage
13=0.5 Start Freq
14=0 Load Pattern select
15=5 Jog Freq
16=0.5 Jog accel time
17=0 Mrs input select
18=400 Max Hi Speed Freq
19=888 95% rated motor voltage
20=50 Accel ref Freq.
Should there not be a setting for motor Voltage somewhere ??
George
- You may not post replies
- You may not edit your posts
Forum Rules
