You would not be using the PWM output if you have a PWM to analog converter, you should be using a regular output to supply the converter most converters take a voltage input and convert that to the analog 0-5v / 0-10v some VFD Drives can use 0-5v analog so don't always need 0-10v depends on the VFD Drive spec's
