check the grounding. on the other hand, you can try to use a laptop powered from the battery ( not connected to power outlet ).
Hello all.
I picked up a small CNC router a while back and have replaced the Chinese controller with one from Planet CNC. Everything was working fine up until the other day.
The controller and the computer connect and all works fine until I turn on the spindle. Then the machine disconnects from the computer. If I unplug the cable to the spindle, the computer will not disconnect. The spindle does spin up as it should when the cable is plugged in.
I attached two pictures, one of the laptop screen, and the other of the controller. I have no idea what happened, but I'm sure it's something simple. I tried a different USB cable and made sure the spindle cable was well away from the USB cable. Any help would be appreciated. If there's a thread covering this, please link me to it, I didn't find anything doing a search.
Dan
I had thought of that and tried it, didn't make a difference. I'm going to try connecting to a different computer once I have a moment of free time.
No photos attached they may have high a resolution and need to be corrected to up load
Your wiring is not correct between the VFD Drive and the spindle, this cable is important and needs to be 4 wire plus shielded correctly terminated at each end
The spindle Ground on 4th pin needs to be checked to see if it is connected, the 4th pin needs continuity to the spindle body if it does not then it needs to be corrected, this is a common problem with the Ground wire not being connected inside the spindle to the 4th pin
You will also most likely need a EMI Power Filter also which is mounted close to the VFD Drive Power input supply
Post some photos of what you have
Mactec54
I picked up a new USB cable and it works fine again.
I will definitely check out that ground wire, thanks for the suggestion.
I do recall having this same issue once before, so I check on that and I did the same thing, changed the USB cable and the problem went away.
Dan
The 3 wires are for the 3Ph power they are all carrying power to the spindle you have 3 Hot / Live wires and No Ground this is very bad
You have to have 4 wires it is a safety problem if you don't, the spindle and the VFD Drive must be Grounded with the input power supply Ground to your machine
So the Cable from the VFD to the Spindle needs to be 4 wire Shielded and connected correctly
What size spindle do you have
Mactec54
OK, good to know. I'll order some shielded wire and rerun everything.
The motor is a: 0.8KW water-cooled spindle, 24000RPM
I attached two images, first is the controller. Would I be right to assume the circled terminal not in use is where I would connect the wire? The other image is the top of the spindle and I connect the sire there. However, where would I connect that wire inside the spindle?
Thanks for the help on this.
Correct the spindle Ground Plus the input power supply Ground, the Ground wire inside the top of the spindle should look like this if correctly wired
The cable you should get is CF6-10-04 from IGUS
https://www.igus.com/us/pdf/cf6.pdf
Mactec54
