How do you know the spindle is spinning at 24,000?
Hello . Would you help me. I have cnc spindle with 24000 rpm . I start the motor with HY inverter . I made some settings on the inverter and when i start the motor with maximum speed , on the inverter speed is 6000 rpm .
Settings which i changed are :
PD005 - 400 HZ
PD004- 400 HZ
PD003 - 400 HZ
PD072 - 400 HZ
Thank you very much and have a nice day.
- Huanyang 2.2kw Inverter and 2.2kw 220v spindle
- Need Help!- Chinese, 220V, 1.5 kW, water cooled spindle motore
- Problem- Need Help - 1.5kW Chinese Air-Cooled Spindle and Yaskawa J1000 Inverter 220V/3Phase
- Need Help!- Mach3 PWM Spindle Speed Control using 220v 1ph VFD/220v 3ph spindle motor.
- Speed control for a 110VAC spindle motor in 220V enviroment
UCCNC 2017 Screenset
You need a few more Parameters set try these
Huanyang Mactec54
2.2Kw 220v 400Hz Air Cooled
PD000=0 ( 1 For Parameter Lock )
PD001=0 (1 For Remote Control)
PD002=0 ( 1 For 0-10v Terminal Control or Remote Trim Pot Control )
( J1 Also Needs to be set for Remote Terminal Control 1-2 jumper connection )
PD003=400
PD004=400
PD005=400
PD006=5
PD007=20
PD008=220 (Motor Rated Voltage )
PD009=15
PD010=15
PD011=120 ( 120 Minimum Setting VFD, 150 is Safe for air cooled for startup )
PD13= 08 is for Factory reset, Only use this to set VFD to Factory Default Settings
PD014 Acceleration=8 ( Adjust to suit )
PD015 Deceleration=8 (Adjust to suit )
PD023=0 ( Forward Run Only )
PD041=8 ( Carrier Frequency up to 10 Max for these Spindle motors)
PD120=120 ( Stall Prevention )
PD141=220 ( Motor Rated Voltage )
PD142=9 ( Motor Max Amps 2.2Kw Spindle 9 amp )
PD143=2 ( Motor Number of Poles)
PD144=3000 (Max Motor RPM) 3,000= (24,000)
PD70=0 ( This may need to be set to 1 if Control Voltage is 0-5v )
PD72=400
PD73=120 ( 120 Minimum RPM Setting 150 is Safe for air cooled spindles at startup )
PD174=??? ( To Be Set to the VFD Drives Max Rated Output Amps )
Mactec54
Mactec54 thank you for your help. I made this settings which you say . Now maximum speed is 16000 rpm . I have a another problem . When I stop with stop button on the inverter the motor is still working with 1700-1800 rpm and it dont want to stop. Would you help me to figure out how to remove that problems.
I also try to connect the inverter to the mach 3. I read in the forum but i dont find what to do. I made some pictures of the wiring .
https://ibb.co/3cD2HX4
https://ibb.co/4mqyPWT
https://ibb.co/XsFW8Np
https://ibb.co/r2FzV3c
Would you tell me how to connect the inverter to the cnc board and how to change mach 3 settings ?
Thank you and have a nice day.
Before you connect the VFD Drive to Mach3 you need to have it running correct it sounds like you have set some incorrect Parameters as the Stop Button is always active even when it is set up for remote use
You are using the wrong type of wire / cable you have to use a shielded cable from the VFD Drive to the Spindle and the Shield has to be connected at both ends to Ground not the Ground wire so this cable has to be 4 wire Shielded spindle and VFD Drive must be Grounded
The I/0 cable should also be shielded this can be made from an old computer cable like a mouse cable Etc
You need a 12v DC supply to the Breakout Board when you get to that part, but first get the VFD Drive running correct
So this Parameter needs to be set to ( 1 ) PD024=1 Stop Button Control
Disconnect your remote wires until you have the VFD Drive working correct
Is the J1 Jumper set in the right position
To use the Pot the J1 Jumper has to be in the right position and PD070=1
If you have the Parameters set correct your spindle can not run at 1800RPM the minimum RPM for your spindle should never be below 7200RPM and then you have to watch it does not over heat, the minimum speed is controlled by Parameters
PD011=120
PD073=120
Mactec54
Mactec54 you are the best. Tomorrow i will buy new cables. Then i try again. Would you tell me more information for this connection with this shield cable . My system have only 2 wire . I don't have ground . I make connection between ground and zero with one cable . Do you know how to connect this shield cable for my system ?
About 1800 rpm . The situation is : I start the motor. It works max with 16000 rpm and min 7200 rpm . When i want to stop the motor I push the stop button on the inverter . The motor change rpm from 16000 to 1800 and dont want to stop.
About breakout board I have 12v DC but I can't understand where to connect the cable.
You either have a Bad VFD Drive or you have Programed it incorrectly
You must Have a Ground wire or you can not run this safely your supply power system there will be a Ground / Earth wire Connection, so you must have a 3 wire going to the VFD Drive main power supply ( Live Hot wire ) ( Neutral wire ) ( Ground / Earth wire )
What country do you live in and I will check how your power system is configured
Mactec54
You have to set this Parameter if it is not set to ( 1 ) then it will not stop with the Stop Button
The 12v Dc is connected to the terminal block where the relay output is
The screw down from the top of the Terminal #3 is common / Ground Connection screw #4 is 12v / 24v Dc Power if it is not marked on the top of the board look on the underside
Mactec54
I am from Bulgaria . My system is 2 wire because i live in old house . I can't put new system because i have concrete everywhere . Next year i will make garage and 3 wire system. Now i understand where to put the 12 DC v . Would you tell me about another cables . I made this :
conection between 0-10 v and AI ( on iverter)
conection between GND (breakout board ) and ACM ( inverter)
conection between 1 port from relay to FOR (inverter)
conection between 2 port from relay to DCM ( inverter)
It would be unsafe to use a VFD Drive without a Ground your spindle also needs a Ground, there must be a Ground at the Main Service Box supplying your house
So do not run until you find out how you can Ground your system VFD Drive Spindle and any Power supplies you are using all must be Ground
This is how the VFD Drive should be connected to the Breakout Board for On /Off and 0-10v Speed control
Mactec54
I called to electrician and he made the ground. Now everything is ok . I connected the VFD drive with breakout board . Now if i made some settings in mach 3 i think everything will work. On my breakout board i have pin 14 , 16 ,17 which are outputs . I dont put any cable there.
