Problem with low speed starting spindle 2.2kW DeltaVFD
Results 1 to 2 of 2
Thread: Problem with low speed starting spindle 2.2kW DeltaVFD
    MarkoTr's Avatar
    Nov 2020
    Default Problem with low speed starting spindle 2.2kW DeltaVFD
    Hello everyone, I have a problem with port 1. isolated output on AXBB.
    My system contains:
    1) Delta vfd
    2) SHCRACK relay 24VDC
    3) MV power supply 24v-36W-1.5A
    4) AXBB E
    5) Spindle 220V 3KW (only use M3)
    I connect: Delta-AXBB (AVI/AO1 ACM/5V0)
    Relay-AXBB-PowerSupply (A1/Port 1. Isolated Output O3 A2/24V)
    DeltaVFD-Relay (MDI/NO14 DCM/COM11)
    Spindle speed control (0-10V) works perfectly. But from some reason, when I try to turn on the MACH 3 software at maximum speed, everything works normally, and when I measure the voltage on the incoming relay signals (A1 and A2), I have 24V. As I try to reduce the speed of the spindle, the voltage at the input (A1 and A2) starts to drop, and it increases at the isolated output O3, and my spindle shuts down. It's not clear to me why this happens since I don't use any other outputs, they are all disabled by software when they are NPN type.
    Everyone's opinion would mean a lot to me. Thanks in advance.
    Member mactec54's Avatar
    Jan 2005
    Default Re: Problem with low speed starting spindle 2.2kW DeltaVFD
    Quote Originally Posted by MarkoTr View Post
    My system contains:
    1) Delta vfd
    4) AXBB E
    You either have something wired incorrect or the VFD Drive is programed incorrect
    What is the Delta VFD Model number ???
    Mactec54
