Nobody that can send me in the right direction?
Hello,
I would like to use a second spindle on my dual z setup instead ot the spindle/router setup i have now.
The problem is i don't know howto approach the connection of the second spindle onto the BOB.
On the BOB(avid cnc/cncrp) i only have one spindle relay and one 0/10v vfd steering.
Both spindles are different :
spindle 1 max freq of 400hz / 1x220v
spindle 2 max freq of 300hz / 3x220v
Any help would be apreciated!
Stay safe,
Adam
Mactec54
thanks for the input!
After talking with a friend who is an electronic engineer, he suggested to work with 2 relay's to swith the on/off and the 1/10V signal with another output signal.
I've ordered an 8 relay SPDT and will try it this way first.
Keep safe,
Adam
Both spindles do not run at the same time, but serve as a "toolchanger" with 2 tools
At the moment i'm using a relay to switch contact between spindle on and router on. I suppose it would be possible to "swap" the 0-10 V signal also.
In mach 4 i think i can setup a second spindle with different configs?
There will be some programming needed.
