AC servo as spidle
Results 1 to 4 of 4
Thread: AC servo as spidle
    Mar 2013
    Romanaia
    Default AC servo as spidle
    Hello,
    Does anyone know how to wire an ac servo as a spindle? My controller which is Chinese SMC55N, has PWM,+10v and CW/CCW and of course, a bunch of output signals for relays. The servo is a cheap (also) Chinese one, 3kw and require +10V, -10V, analog ground and DIR information for controlling it in Speed Mode.
    Default Re: AC servo as spidle
    once mine arrives i'll be sure to let you know hahaha
    Member cncmakers001's Avatar
    Jul 2011
    China
    Quote Originally Posted by Ilerim View Post
    Hello,
    Does the controller come with a User manual?
    Or you can ask the maker to send you a PDF file.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Dec 2003
    If this is a typical P.M. AC or BLDC servo, you cannot use a common VFD for a controller.
    I have tried it with very poor success.
AC servo as spidle
AC servo as spidle
