Running a 5.5/7.5 kw 8000 rpm Fanuc motor on a vfd.
Results 1 to 3 of 3
Thread: Running a 5.5/7.5 kw 8000 rpm Fanuc motor on a vfd.
    Default Running a 5.5/7.5 kw 8000 rpm Fanuc motor on a vfd.
    I am building a fixture to "run in" spindles after rebuild. I have a fanuc 8000 rpm motor. (See attached pic of nameplate) the only load on the motor will be a belt driving a free spinning spindle up to 10,000 rpm for an hour at a time. What size VFD do I need, 220 volt single phase input?
    Dec 2013
    Default Re: Running a 5.5/7.5 kw 8000 rpm Fanuc motor on a vfd.
    For that application, a 15HP single phase rated VFD should work OK. Something like this https://www.ebay.com/itm/15-HP-VFD-D...8AAOSwhL5dcnmU
    Jim Dawson
    Sandy, Oregon, USA
    Not sure why pic did not upload but here is is. One VFD supplier told me I need a 30HP VFD without seeing specifications, I just told him amps over the phone.
    Attached Thumbnails Attached Thumbnails Running a 5.5/7.5 kw 8000 rpm Fanuc motor on a vfd.-20201006_141257-jpg
