Monitoring speed, possibly to maintain a constant speed while cutting.
Hi there,
Can someone enlighten me what would be the advantages having an encoder on a high-speed asynchronous spindle?
The encoder is a $500 option on this particular spindle (36000rpm, 5.5kW, max 4Nm torque).
- Need Help!- Bad spindle encoder
- Need Help!- New Spindle Encoder Twice the Resolution of Old Encoder - What to do?
- Spindle encoder
- Need Help!- What is the best spindle encoder?
- Spindle encoder
Can't a sensorless vector drive already do that? Probably to lesser accuracy, but does it matter with such high speeds?
Depends on the type of operations required, one that is typical is to gear an axis off the spindle encoder for threading, but this example is typically used with a slower speed spindle.
Unless you have an application for something of this nature using a H.S. spindle, then it may not be worth it.
Could it be used to do light rigid tapping (M3, M4 threads) ?
