110v CNC Spindle 80mm ER20 Suggestions
Results 1 to 4 of 4
Thread: 110v CNC Spindle 80mm ER20 Suggestions
    Member Sandow12's Avatar
    Dec 2019
    Default 110v CNC Spindle 80mm ER20 Suggestions
    I am in the market to purchase a 110v ER20 Spindle. I would prefer to go air cooled. Does anyone have any suggestions on a specific setup. Been looking at this kit from Amazon.
    https://www.amazon.com/dp/B06ZZSPT5R...v_ov_lig_dp_it
    Jan 2005
    Default Re: 110v CNC Spindle 80mm ER20 Suggestions
    Quote Originally Posted by Sandow12 View Post
    2.2Kw on 110v is junk you end up with around a 800w spindle if you have a 120v service that can run it
    Mactec54
    Dec 2019
    So what would you recommend if I don't have the option for 220v. I have not seen a ER 110v at 1.5kw. A 2.2kw at 110v and 20amp, would that still be junk?
    Jan 2005
    The max you can use on a regular 120v single phase supply is the 1.5Kw 110v spindle, you have to look at the whole picture as there is no such thing as 110v 3phase it is a made up spindle to sell to those that are new to this to look at your 2.2Kw spindle run on 240V NA supply then you still need a 25A supply for it to run correctly
    You are best to run a 240v 30A or 40A supply for your machine this wants to be a 4 wire cable so you can use it as 120v / 240v
    You can use a Transformer 120v to 240v you still need a 25A supply to do this, then you can use the 1.5Kw 220v Spindle
    Mactec54
