Spindle not turning on issues
Results 1 to 3 of 3
Thread: Spindle not turning on issues
    donpablo508's Avatar
    May 2020
    Default Spindle not turning on issues
    Hello,
    I have a CNC machine which has been working fine for 7 years until yesterday. The spindle turned off all of the sudden. Our spindle is a 2.2 KW, 400HZ running with a Fuling Inverter: DZB200B002.2L2DK.
    I can hear the relay turn on and off but the spindle will not turn on. I can hear it wants to start , but it wont start. I'm getting error E013
    Please help me solve the issue
    thank you
    Tony
    Jan 2005
    Default Re: Spindle not turning on issues
    Quote Originally Posted by donpablo508 View Post
    Hello,
    thank you
    Tony
    Did you stall the spindle when it was cutting as that is a over Torque Fault, check that you have set the over torque Parameters and over voltage , Reset clear the fault as per your manual
    Mactec54
    May 2020
    I hit a screw head while cutting , but it didn't stop working immediately. I will try to reset the over torque parameters to see if it solves the issue
    Thank you
