VFD wireing for Acorn board
Results 1 to 2 of 2
Thread: VFD wireing for Acorn board
    Jan 2015
    Default VFD wireing for Acorn board
    I need to know if I need to connect the FWD and common terminal to my acorn board of just the V I and ACM terminals in My VFD
    Member mactec54's Avatar
    Jan 2005
    Default Re: VFD wireing for Acorn board
    Quote Originally Posted by Pa45 View Post
    Depending on the VFD Drive you are using as to how it is connected but normally you would use one of the Acorn relays to turn it On / Off FWD and DCM connection VI and ACM is only for your speed control
    Mactec54
