They look ok, you have listed a lot of Parameters they don't all apply to what you are doing but may not affect anything being set Here is a basic list that you can compare with that has worked for other users with this VFD Drive
Have you test run your spindle, make sure the 4th pin Earth/ Ground is connected inside the spindle you can check this with a meter you should have continuity between the 4th pin and the spindle body
Mactec54
Spindle Cable IGUS CF6-15-04 PH 401-438-7270
Huajiang VF Drive
YL 600/620 220 2.2Kw Water Cooled
P00.00=400
P00.01=0
P00.04=400
P00.05=400
P00.06=110%
P00.07=140
P00.08=35%
P00.09=120
P00.10=30%
P01.00=1
P01.03=100%
P01.04=110%
P01.08=110%
P03.08=120
P03.09=400
P06.01=8 ( Acceleration Adjustable )
P06.02=8 ( Deceleration Adjustable )
P0700=400
P07.08=0
P11.01=220 ( May be 2 for 220v )
P11.02=9
P11.03=400
P12.00=9
P12.01=220
P12.02=2
P12.03=6.5
P12.05=10
P12.06=220
