What is that web site and model printed on the board,?
hey guys .. you guys are alot of help... im new here and im putting together my cnc build...
im tryin to wore my HY VFD to my break out board but i dont have the NVUM i have a the one that comes in a kit ill post a pic of it... can someone help me with wireing from VFD to this BoB i just need to be able to turn the spindle on and adjust speed...thanks.
its the bitsensor.com
BSMCE04U-PP
i tried to look it up.. i know from my VFD i have to run from DCM , FOR , ACM , and V1 but idk where to wire them to my BoB
at least i think thats what i need
There is a few details on hook up out there if you Google, it does not seem to have a good reputation according to Mach sites etc.
Also a mention of the Manuf. not supporting it any more and seems to have skipped!
What is the 16pin IC device # next to the outputs?
Al..
not sure what that 16pin is...
BTW, there are series of Utube videos that show the installation, set-up and usage of that BOB, the videos are by BuildyourCNC.
yes i saw those videos... but they dont show the wiring for the VFD. they show everything but that...
One showed the relay hook-up for FWD REV?
There is also a wiring diagram out there that shows the input to the VFD relay in and AV1-AV2 for the analog.
still no luck... im about to give up on it...
This board does not have a PWM to Analog 0-10v output so it can not control the spindle speed, you can use an output to a PWM to Analog 0-10v board a Relay can be on this same Board as well for the On / Off control
A board like this or one with a Relay as well will do the job
Mactec54
Hi everyone.
BSMCE04U module.schematic.
https://www.cnczone.com/forums/contr...cnc-posts.html
RV mineirin
