Trouble with Huanyang 2.2kw 110v spindle/VFD
Results 1 to 3 of 3
Thread: Trouble with Huanyang 2.2kw 110v spindle/VFD
    Member Kagstand's Avatar
    Feb 2020
    Default Trouble with Huanyang 2.2kw 110v spindle/VFD
    Been trying to get ahold of someone, anyone from this company
    for three days and not a word. Does anyone know how to get in touch
    with these people? I guess this is what I get for trying
    to save a few bucks.
    Member CitizenOfDreams's Avatar
    Nov 2012
    Default Re: Trouble with Huanyang 2.2kw 110v spindle/VFD
    What would you talk to them about?
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by Kagstand View Post
    I'm quite sure you won't get a response direct from Huanyang it may take a while if they do respond, they don't deal direct with the customer normally, you have to go through who you brought it from and why would you buy a 2.2Kw 110v as this would perform very poorly
    1.5Kw is normally around the max for a 120v supply your VFD drive should be 120v input 220v output and a 1.5Kw 220v spindle
    If you are trying to run it on a 15A circuit then this will fail to supply enough current ( amps ) needed to run your 2.2Kw spindle
    Mactec54
