Need Help!- Huanyang VFD + Usb 4 Axis Mach3 100 Khz Usb
Results 1 to 4 of 4
Thread: Need Help!- Huanyang VFD + Usb 4 Axis Mach3 100 Khz Usb
    Member taths's Avatar
    Oct 2019
    Default Need Help!- Huanyang VFD + Usb 4 Axis Mach3 100 Khz Usb
    I have this controller Usb 4 Axis Mach3 100 Khz Usb, and Huanyang VFD, I tried everything, but it didn't start some help ?
    Attached Thumbnails Attached Thumbnails Need Help!- Huanyang VFD + Usb 4 Axis Mach3 100 Khz Usb-s-l1600-jpg   Need Help!- Huanyang VFD + Usb 4 Axis Mach3 100 Khz Usb-img_20200215_073320-jpg   Need Help!- Huanyang VFD + Usb 4 Axis Mach3 100 Khz Usb-img_20200215_073343-jpg
    Jan 2005
    Default Re: Need Help!- Huanyang VFD + Usb 4 Axis Mach3 100 Khz Usb
    Quote Originally Posted by taths View Post
    Do you have a wiring diagram you can post of the Breakout Board, it does not appear to have a Relay or PWM 0-10v analog output
    Mactec54
    Oct 2019
    Thanks for the answer, photo with connectors,sorry for my english, i use translation.
    Jan 2005
    Check that the ACM and DCM are the same if not they can not be connected / wired like that ACM is Analog Common DCM is DC Common
    FWD and output 2 I don't think will work for your VFD Drive, what does output 2 do, if this has voltage then it will not work it would have to turn a Relay On / Off to be used if it has a voltage FWD and DCM is just a switch with no voltage to make the VFD Drive turn On / Off
    Mactec54
