Driving a VFD with another VFD? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Thread: Driving a VFD with another VFD?
  1. #21
    Nov 2017
    Netherlands
    Default Re: Driving a VFD with another VFD?
    I hooked up my spindle motor and configured the VFD with some very conservative settings...and it works! best €4 I ever spend haha. Thanks for all your help
  2. #22
    Jan 2005
    Quote Originally Posted by metiz View Post
    If the VFD can only be programed to 120Hz max then you will burn smoke your 400Hz spindle so don't run it to long or your cheap drive will be an expensive drive when you have to replace your spindle motor as well
    Mactec54
  3. #23
    Nov 2017
    Netherlands
    How does a low frequency burn a motor? The inverter I got with the spindle motor (as a set) can be set with a pot from 0 to 400hz. I also set the drive for a low current and voltage
  4. #24
    Jan 2005
    I guess you will find out the VFD Drive Parameters must be set to the 400Hz or the motor spec's for the spindle to survive
    Mactec54
