- Spindle smoke - confirmation
After rearranging the cables I forgot to screw up ground to VFD, but at the same time, it was soldered to the spindle. All other VFD setting was there, spindle switched on from mach3 and magical smoke appears. I suppose I burned it down definitively since EOAC appears next time tried to run?
- You may not post replies
- You may not edit your posts
Forum Rules
