water spindle
Results 1 to 2 of 2
Thread: water spindle
    May 2004
    Default water spindle
    I got a cnc router with water spindle, the water has a lot of rust and oter things in, the spindle can be turned by hand it is not locked up. What is the best way to clean it and flush it out. Thanks Dan
    Member routalot's Avatar
    Dec 2003
    Default Re: water spindle
    Don't plumbers use something for flushing crud from radiators?You might start by calling a tame plumber but be cautious about sending electricity through until you are sure the cooling circuit hasn't corroded to the point where it might allow water to pass through and short the motor-or worse.
water spindle
water spindle
