Need Help! problem with Huanyang 4kw vfd
Results 1 to 6 of 6
Thread: problem with Huanyang 4kw vfd
    May 2010
    Denmark
    Question problem with Huanyang 4kw vfd
    Hi
    i have a problem with my 4kw VFD with is a 4kw 18000rpm spindle
    i can fine get the spindel to 18000 rpm and 300hz
    but if i set the mach3 to 9000 rpm the the vfd is showing 174.5hz and not 150hz
    and i have measured the pwm signal to 5v
    now i have use two days and i cant find the error
    /kenneth
    Jan 2005
    Default Re: problem with Huanyang 4kw vfd
    Quote Originally Posted by tkoc View Post
    Hi
    /kenneth
    What Parameters have you set in the VFD Drive
    What is your spindle spec's
    Max RPM=
    Amps=
    Voltage=
    Max Hz=
    Mactec54
    May 2010
    Denmark
    spindle
    Voltage: 220VAC
    Current: 10A
    Frequency: 0-300Hz
    Speed: 0-18000rpm
    PD001=1
    PD003=300
    PD004=300
    PD005=300
    PD007=20
    PD008=220
    PD009=15
    PD010=8
    PD011=40
    PD014 Accel=12
    PD015 Deccl=12
    PD141=220 ( Motor Rated Voltage )
    PD142=10
    PD143=2
    PD144=3000
    Jan 2005
    spindle
    Voltage: 220VAC
    Current: 10A
    Frequency: 0-300Hz
    Speed: 0-18000rpm
    PD001=1
    PD003=300
    PD004=300
    PD005=300
    PD007=20
    PD008=220
    PD009=15
    PD010=8
    PD011=40
    PD014 Accel=12
    PD015 Deccl=12
    PD142=10
    PD143=2
    PD144=3000
    Is your Spindle Air cooled or Water Cooled ???
    PD014= you seem to have a high setting for this normally you can go as low as 3 so anywhere from 3 and up should work fine
    PD015= you seem to have a high setting for this normally you can go as low as 3 so anywhere from 3 and up should work fine
    Jumper J1 also must be set for Remote Control This is located next to the Terminal Block
    PD002=1
    PD011=120 Not 40 this is below the minimum speed for your spindle
    PD70=0 ( This may need to be set to 1 if Control Voltage is 0-5v )
    PD72=300
    PD73=120
    PD120=120 (Stall Prevention )
    PD174=?? ? ( Your VFD Drives Max Amp Output Rating )
    Mactec54
    Member Velikivrh's Avatar
    Nov 2019
    Way pd 144 =3000 ist this max rpm of motor?
    Jan 2005
    Quote Originally Posted by Velikivrh View Post
    Yes that is the max setting for that Parameter PD144=3000=Max Spindle RPM what ever it is
    Mactec54
