Frequency control by frequency
Results 1 to 2 of 2
Thread: Frequency control by frequency
    Member cedric087's Avatar
    Oct 2019
    Default Frequency control by frequency
    Hello
    I have an Altivar 12 2.2KW and I use the PlanetCNC CNC3 / 4 Controller USB Controller.
    https://www.se.com/ww/en/product/ATV...e-speed-drives
    My card can handle the speed of my spindle by the frequency which will avoid the addition of a card to switch from PWM to 0-10V.
    Is it possible with my Altivar 12 to control it by frequency?
    Attached Thumbnails Attached Thumbnails Frequency control by frequency-planet-jpg
    Member mactec54's Avatar
    Jan 2005
    Default Re: Frequency control by frequency
    Quote Originally Posted by cedric087 View Post
    Hello
    No your VFD does not accept frequency for control and very few do
    You have PWM in your programing that should output the 0-10v you need
    Your VFD Drive can use Modbus or 0-5v and 0-10v to control the speed
    Make sure the VFD Drive has all your spindle spec Parameters set
    Mactec54
