Huanyang VFD HY01D511B potentiometer issue
Results 1 to 9 of 9
Thread: Huanyang VFD HY01D511B potentiometer issue
    Jan 2011
    Default Huanyang VFD HY01D511B potentiometer issue
    Hi
    I have a Huanyang VFD HY01D511B 110V 1.5kw, and when I turn it on, the potentiometer display turns on as usual and when I press the run key,
    the spindle start until it reach the maximum speed, without turning the speed knob of the potentiometer wich remain at zero. (seems disable).
    I had previously program VFD PD.... according to instructions obtained from Mactec54 post
    "This is all you need, all the basic Parameter Settings are the same for all the 400Hz Spindles, just voltage and Amps that are different
    Don't do a Reset unless you have to, sometimes doing this affects the order of how the Parameters get set
    " Huanyang Mactec54
    PD000=0 for Parameter unlock ( 1 ) for Parameter Lock
    PD001=0 (1 For Remote Control)
    PD002=0 ( 1 For 0-10v Terminal Control or Remote Trim Pot Control )
    ( J1 Also Needs to be set for Terminal Control )
    PD003=400
    PD004=400
    PD005=400
    PD007=20
    PD008=220 (120 If you have 120v VFD )
    PD009=15
    PD010=8
    PD011=120 ( 100 Minimum Setting with Quality VFD, 120 is Safe)
    PD13= 08 is for Factory reset, Only use this to set VFD to Factory Default Settings
    PD014 Acceleration=12 ( Adjust to suit)
    PD015 Deceleration=12 (Adjust to suit)
    ( PD15 is ignored IF PD26=1 Then the Spindle will Coast to a Stop)
    PD141=220 ( Motor Rated Voltage ) (120 for VFD Rated for 120v )
    PD142= ( Motor Max Amps)
    PD142=( 220vSet for your motor Amp Rating 2.2Kw Spindle 9 amp )
    PD142=( 220VSet for your motor Amp Rating 1.5Kw Spindle 7 amp )
    PD142=( 220v Set for your motor Amps Rating 800w Spindle 4 amps )
    PD142=( 120v Set for your motor Amp Rating 800w Spindle 7 amp )
    PD143=2 ( Motor Number of Poles)
    PD144=3000 (Max Motor RPM) =3,000= (24,000)
    PD70=0 ( This may need to be set to 1 if Control Voltage is 0-5v )
    PD72=400
    PD73=120 ( 100 Minimum Setting )"
    Does anyone have an idea of the problem ? Should I do something with the J1 jumper ?
    Thank you
    Jack
    Attachment 430160Huanyang VFD HY01D511B potentiometer issue-img_0415-2-jpg
    Jan 2011
    Default Re: Huanyang VFD HY01D511B potentiometer issue
    Hi
    Problem Fixed
    Here is the change I've made in my parameters:
    PD002 was change from 0 to 1
    PD070 was change from 0 to 1
    I tried to change them before but not both simultaneously.......without success
    Thank you
    Jack
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by JackMath View Post
    Hi
    Problem Fixed
    Thank you
    Jack
    Yes that is the fix for pot use on some of these VFD Drives as per what is written beside each of the Parameters in the list you posted, there is always a possibility that they may need to be changed depending on the operation you are wanting to do with the KeyPad
    Sometimes you need to change the J1 Jumper also
    Mactec54
    Jan 2011
    Thank you Mactec54
    I often hear about jumper j1 but I have not yet spotted it, could it be that in my case it is the jumper V1 / VR as in the photo attached ?
    Jack
    Huanyang VFD HY01D511B potentiometer issue-img_0421-jpg
    Jan 2005
    Thank you Mactec54
    Jack
    That is the normal location of the Jumper for remote use
    Do you have a PDF manual that you could post here of your drive, I have seen V1 / VR before would like to see what is in the manual
    Mactec54
    Jan 2011
    no pdf but manual page as per photo attached regarding V1-VR jumper wich appears to be the same as jumper J1
    In my case, I left the jumper as shipped by the factory, position 2 and 3 and it work fine.
    jack
    Huanyang VFD HY01D511B potentiometer issue-capture-d-cran-20-jpg
    Huanyang VFD HY01D511B potentiometer issue-img_0423-jpg
  7. #7
    Jan 2011
    jack
  8. #8
    Jan 2005
    jack
    Are they are still calling it a J1 that's important as I thought by your post it may have changed how it was used, but it is the same just giving the jumper positions a name VI and VR
    Mactec54
  9. #9
    Jan 2011
    Yes they are still calling it J1 (with subtitle V1-VR) as you can see here in a closeup picture attached
