Newbie Huanyang Inverter + Next Wave Automation CNC
Results 1 to 5 of 5
Thread: Huanyang Inverter + Next Wave Automation CNC
    Member madmaxh3's Avatar
    Oct 2019
    Default Huanyang Inverter + Next Wave Automation CNC
    O.k., I've got a 2.2 Kw inverter and a Piranha XL controller, is there any way to enable spindle on/off ?
    I am not afraid to open the case of the controller, nor am I afraid to do some soldering, if I have to.
    Any help would be GREATLY appreciated.
    Jan 2005
    Default Re: Huanyang Inverter + Next Wave Automation CNC
    Quote Originally Posted by madmaxh3 View Post
    After looking up what you have contact the manufacture
    Mactec54
    Oct 2019
    mactec54,
    I believe I know the correct parameters for the VFD. Attached are three photos of the BOB (not pro quality, sorry).
    Attached Thumbnails Attached Thumbnails Huanyang Inverter + Next Wave Automation CNC-image3-jpeg   Huanyang Inverter + Next Wave Automation CNC-image4-jpeg   Huanyang Inverter + Next Wave Automation CNC-image5-jpeg
    Jan 2005
    mactec54,
    The next wave I believe is a bad idea, you need a Relay to switch FOR and DCM on the VFD Drive if the Next wave has a spare output that could turn a Relay On /Off that is all you need I don't see a Relay on there Board
    It's just a switch with no voltage on the Relay output
    Mactec54
    Oct 2019
    Thanks mactec54,
    I think I have a relay that will work, I'll check it out.
