Hello. I am sending 2 pdf manuals to see if anyone can help me adjust what I need.
Hello, sorry my english (google translator).
I really need your help.
I bought a Fvd and I can't show the Rpm on the display, just shows the frequency. In the manual does not say where to change this option, and already read in several places to change the parameter p144, but in my model this parameter does not have.
https://pt.aliexpress.com/item/32807...2742b90atvjpGQ
110v 2.2kw
Thanks a lot if anyone can help me
Looks like set P00.24 = 6
Maybe also need to adjust P00.23, but I think not.
Jim Dawson
Sandy, Oregon, USA
Thanks, I did that what you said, I had tried that too.
But it still didn't work.
In P00.23 it only adjusts from 0 to 100.
in P00.24 I put in 6. Now shows on the display SP 1.
There must be somewhere else to change, but I don't know where, this is hard.
Hello, I have the same vfd did some one find out how to display rpm instead frequency on yl620-a?
Following are the settings and examples for what worked for me to display RPM. It is similar to what @mactec54 has suggested.
Two parameters in the YL620 VFD allow to display the RPM of the motor, and also to factor the gear ratio between the motor and the end spindle.
These parameters are:
- P00.24 Display Mode
- P00.23 Display Proportion Constant
The following examples were done with a YL620 VFD (200VAC, 50Hz) connected to a single-phase induction motor (220VAC, 50Hz). The inner capacitor of the motor was removed and the two windings of the motor (`start` and `main` windings) were connected to the U, V, and W outputs.
The basic parameters for the following examples are:
- P00.04 Max Frequency = 50 Hz
- P03.08 Panel Potentiometer Lower Frequency Limit = 20 Hz
- P03.08 Panel Potentiometer Upper Frequency Limit = 50 Hz
### Example 1
The above mentioned two parameters for displaying the RPM (also factoring the gear ratio) are:
- P00.24 Display Mode = 9 (display user variable)
- P00.23 Display Proportion Constant = 200% (Hz to RPM conversion ratio of 2)
In this case, when the motor runs the display will show the following messages depending on the speed set by the potentiometer:
For minimal speed: "u 400"
For maximal speed: "u1000"
Please note that there is no decimal point in this example. I think this is a bug in the firmware installed on my VFD.
As a workaround I set the P00.23 to 20% instead of 200% and got:
For minimal speed: "u 40"
For maximal speed: "u 100"
This refers to 40 RPM and 100 RPM, respectively. In this case they represent RPM which is 2 times the motor frequency.
### Example 2
- P00.24 = 9 (display user variable)
- P00.23 = 40% (Hz to RPM conversion ratio of 4)
Note that due to the decimal point presumably bug, P00.23 is set to 40% instead of 400%.
The displayed range now for the new scaling value is:
For minimal speed: "u 80"
For maximal speed: "u 200"
This is exactly what I was looking for.
Note also that with P00.24 = 9 (display user variable), you can scroll through various displayed content by pressing the `SET` key. There are about 13 types of displays that can can be scrolled through on the fly (without pre-programming), including most of the types listed for P00.24 possible values. This can be done even when the motor is running.
Enter on 00.23 = 50/60HZ it depends on where you are in Italy and 60hz
Enter on 00.24=0
Press the program button to return to the frequency, then press nine times on set until you reach RPM spindle on the display there is a lowercase u on the bottom left with the engine running you will see the engine rpm
Hello as I am new in this forum and I would like to understand my cnc machine well I followed the discussion regarding the vision of the spindle speed and I set those parameters to be able to see it the main parameters are on 400hz but I notice that the spindle heats up after 15 minutes even if I take it over six thousand turns my spindle and the one in the attached photo and I have a YL620-A vfd
Mactec54
These are the parameters stored on my Vfd
P00.00=400
P00.01 = 0
P00.02=0
P00.03=0
P00.04 = 400
P00.05 = 400
P00.06 = 100.0
P00.07 = 400
P00.08 = 146
P00.09 = 0.2
P00.10 = 2.0
P01.00 = 0
P01.01=0.0
P01.02=140
P01.03 = 140
P01.04 = 200
P01.05=130
P01.06=120
P01.07=80
P01.08 = 150
P03.08 = 40.0
P03.09 = 400
P06.01 = 10
P06.02 = 10
P0700 = 0.1
P07.08 = 0
P11.01 = 220
P11.02 = 7.0
P11.03 = 400
P12.00 = 5.0
P12.01 = 220
P12.02 = 2
P12.03 = 30
P12.04=5
P12.05=6,5
P12.06=220
P12.07=140
P00.00=400
P00.01 = 0
P00.02=0
P00.03=0
P00.04 = 400
P00.05 = 400
P00.06 = 100.0
P00.07 = 400
P00.08 = 146
P00.09 = 0.2
P00.10 = 2.0
P01.00 = 0
P01.01=0.0
P01.02=140
P01.03 = 140
P01.04 = 200
P01.05=130
P01.06=120
P01.07=80
P01.08 = 150
P03.08 = 40.0
P03.09 = 400
P06.01 = 10
P06.02 = 10
P0700 = 0.1
P07.08 = 0
P11.01 = 220
P11.02 = 7.0
P11.03 = 400
P12.00 = 5.0
P12.01 = 220
P12.02 = 2
P12.03 = 30
P12.04=5
P12.05=6,5
P12.06=220
P12.07=140
Mactec54
