Need Help! 3Kw 220V spindle issues.
Page 1 of 3 123 LastLast
Results 1 to 12 of 26
Thread: 3Kw 220V spindle issues.
    Member DemBones's Avatar
    Jul 2019
    Default 3Kw 220V spindle issues.
    I have a spindle that has been working until today. The spindle will start when I hit the spindle control in Mach3 and then (not immediately) shut down. I get an HoC code on the front of the VFD. I removed the wire connection to the top of the spindle and ran the spindle with Mach3 again. I can get it up to 400 and back down without any code. I assume this means that my spindle is bad but why would it startup in the first place.
    Can anyone tell me if the spindle is truly bad and if I need to replace or is it something else?
    I tried everything to post the video but I was unable. So here is a link to the video
    https://drive.google.com/file/d/1_V9...ew?usp=sharing
    Sep 2005
    Default Re: 3Kw 220V spindle issues.
    Find your manual and look up the code that is displayed. If you have to spin it to start you might have a missing phase connection either in the motor or drive wiring to the motor.
    https://www.fluke.com/en-us/learn/bl...vfd-to-a-motor
    https://www.motioncontroltips.com/tr...-power-checks/
    Never depend on checking from a VFD output to ground as it needs to be phase to phase check.
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
    Jan 2005
    Quote Originally Posted by DemBones View Post
    What VFD Drive do you have model number and brand name
    This can be many different problems as the spindle did not reach max speed, increase the ramp up to speed time Parameter
    Mactec54
    Jul 2019
    it is a "Best" VFD
    Attached Thumbnails Attached Thumbnails 3Kw 220V spindle issues.-best-vfd-jpg
    Jul 2019
    No, I don't have to spin it to start, that was to just show it spins freely.
    Jan 2005
    it is a "Best" VFD
    Ok check P038 and see what you have this may be set to low
    P038=
    Because you have been running for some time first check the spindle with a meter
    From the spindle plug
    Pin 1 to Pin 2=
    Pin 2 to Pin 3=
    Pin 3 to Pin 1=
    Pin 4 to spindle Body ( this is Ground )
    And all Pins to the Spindle Body
    Then check the Cable from the VFD Drive to the Spindle, and inside the plug connections
    Why do you have to check this, this Fault indicates that there could be a short in your wiring or your Spindle
    Attached Thumbnails Attached Thumbnails 3Kw 220V spindle issues.-hoc-fault-png
    Mactec54
  7. #7
    Sep 2005
    Who made up the cable from the VFD output to the spindle and plug? Very possible you have a loose or broken connection. Or the wires inside the cable end plug are shorted or open.
  8. #8
    Jul 2019
    The company made the cable. I have asked the company for a manual and the parameters for the VFD but they have not responded. I'm not sure how to work the VFD but did put in P038 and pushed the button and it shows a 6.0. Would that be a correct number? I will check for a short between the wires today and post the results.
    Thanks for the help and direction
  9. #9
    Jul 2019
    I just checked the wires on the spindle side and the plug side and there were no shorts. The ground pin was shorted to the case on the spindle side but that was it.
  10. #10
    Jan 2005
    Yes that number would be Ok
    Mactec54
  11. #11
    Jan 2005
    What where the continuity reading between the Pins as I posted at the Spindle only
    Mactec54
  12. #12
    Jul 2019
    between all of the pins read 0.8 ohms and nothing or open between the ground pin and others.
