Need Help! 2.2kw 24000rpm Huanyang Spindle won't exceed 12000rpm
Page 1 of 4 1234 LastLast
Results 1 to 12 of 37
Thread: 2.2kw 24000rpm Huanyang Spindle won't exceed 12000rpm
    Member rosevelt155's Avatar
    Aug 2019
    Default 2.2kw 24000rpm Huanyang Spindle won't exceed 12000rpm
    I have a Huanyang 2.2 kW water-cooled spindle and I'm controlling it with Mach 4. The spindle will only go up to 12000 RPMs instead of the 24000 RPMs that it is supposed to be running at. I have tried a total factory reset of the VFD but it still does not work. The spindle runs fine and at the correct speed anywhere from 7200 RPMs to 12000 RPMs. The rpm of the spindle is checked with a laser tachometer. Any ideas? Here are my settings:
    PD001 1
    PD002 1
    PD003 400
    PD004 400
    PD005 400
    PD006 3.0
    PD007 1.2
    PD008 220
    PD009 15
    PD010 8
    PD011 120
    PD014 2
    PD015 2
    PD070 0
    PD072 400
    PD073 0
    PD141 220
    PD142 8.5
    PD143 2
    PD144 3000
    Mar 2003
    Shelby Township
    Default Re: 2.2kw 24000rpm Huanyang Spindle won't exceed 12000rpm
    How are you controlling it?
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
    Aug 2019
    I am using a Pokeys57CNC controller with Mach 4
    Feb 2009
    I think you need to narrow down whats causing it. Put the VFD in manual mode and see if you get the 12K or 24K manually. If it's still not right in manual, then you know its in the VFD.
    Aug 2019
    I checked the VFD in manual mode and I get a full range of 7200-24000 RPMs.
    Jan 2005
    Quote Originally Posted by rosevelt155 View Post
    PD001 1
    PD002 1
    PD003 400
    PD004 400
    PD005 400
    PD006 3.0
    PD007 1.2
    PD008 220
    PD009 15
    PD010 8
    PD011 120
    PD014 2
    PD015 2
    PD070 0
    PD072 400
    PD073 0
    PD141 220
    PD142 8.5
    PD143 2
    PD144 3000
    What is your voltage out to the VFD drive 0-10v if it is 5v then change this Parameter
    PD070=1
    PD006=15
    PD007=20
    PD010=10
    PD041=8 ( Carrier Frequency up to 10 Max for these Spindle motors)
    PD174= ??? ( To Be Set to the VFD Drives Max Rated Output Amps )
    Make sure PD143=2 that it is set to ( 2 )
    Mactec54
  7. #7
    Aug 2019
    Yes, my controller voltage is 0-10v and I checked that with a multimeter. I just tried all those settings and the motor decreased speed down to 8000 RPMs and it went back up to 12000 RPMs when I changed PD006 back to 3.0. PD143 is definitely set to 2 and PD174 is set to 11 amps (from the label on the VFD).
  8. #8
    Mar 2003
    Shelby Township
    How do you have the J1 jumper set?
  9. #9
    Aug 2019
    I am assuming this is to control the VFD with either an external controller or with the onboard potentiometer? If so then yes, it is set correctly
  10. #10
    Jan 2005
    That is very strange PD006=3 would not normally be suitable for your spindle this is for a 50Hz motor setting yours is 400Hz
    What number do you have in PD071=
    You may have a faulty or incorrectly programed VFD
    Mactec54
  11. #11
    Mar 2003
    Shelby Township
    1-2, or 2-3?
  12. #12
    CNCINDUSTRY's Avatar
    Aug 2019
    guangzhou
    Have a try to set PD002=0, which means the operation frequency is set by the keypad.
    Then tune up the frequency by pressing the up arrow key. See if the freq. could be 400Hz or not.
