HY VFD Mach3 Control BOB wiring
Results 1 to 5 of 5
Thread: HY VFD Mach3 Control BOB wiring
    Jan 2005
    Default Re: HY VFD Mach3 Control BOB wiring
    Quote Originally Posted by dbtoutfit View Post
    Can anyone tell me if this look correct?
    No not quite, unless ACM and DCM are the same on your VFD Drive which you would have to check with a meter if they are the same then you are good to go, but normally VI and ACM are the connection for your speed control and FOR and DCM for the relay ON / OFF control
    VI and ACM
    FOR and DCM
    Mactec54
    Dec 2005
    VI and ACM
    FOR and DCM
    Sorry looking back I ment to break the acm-dcm ground bridge from the manual pic.
    So if I run those straight I should be good?
    Would running analog freq (P1) to AI be better than 0-10v to VI to control the spindle speed? TIA.
    Jan 2005
    Most don't bother to even try the AI connection as they don't have the output for it, if the 0-10v does not work then you could try it, there would not be any difference, both will do the same job
    Mactec54
    Dec 2005
    Thanks for the help.
