Vfd YL620-a initial setup
Results 1 to 8 of 8
Thread: Vfd YL620-a initial setup
    Member Terryble24's Avatar
    Jul 2019
    Default Vfd YL620-a initial setup
    Hello guys..im building my first cnc router and im a bit confused with the vfd format. Most of the threads ive read and vids ive watched show changes made to the PD parameters...
    When i powered my vfd for the first time my format is different..it displays P00.00?
    Im using the 2.2kw square air cooled spindle. 220v and 400hz...was wondering if anyone has a list of parameter settings for this particular setup? Thanks for your time..
    Attached Thumbnails Attached Thumbnails Vfd YL620-a initial setup-20190701_174820-jpg   Vfd YL620-a initial setup-20190701_143007-jpg
    Jan 2005
    Default Re: Vfd YL620-a initial setup
    Quote Originally Posted by Terryble24 View Post
    You may have to make some changes but should get you started, you may have to increase the minimum speed Frequency is you get over heating
    Huajiang VF Drive
    YL 600/620 220 2.2Kw
    P00.00=400
    P00.01=0
    P00.04=400
    P00.05=400
    P00.06=110%
    P00.07=140
    P00.08=35%
    P00.09=120
    P00.10=30%
    P01.00=1
    P01.03=100%
    P01.04=110%
    P01.08=110%
    P03.08=120
    P03.09=400
    P06.01=8 ( Acceleration Adjustable )
    P06.02=8 ( Deceleration Adjustable )
    P0700=400
    P07.08=0
    P11.01=220
    P11.02=9
    P11.03=400
    P12.00=9
    P12.01=220
    P12.02=2
    P12.03=6.5
    P12.05=10
    P12.06=220
    Mactec54
    Jul 2019
    Huajiang VF Drive
    P00.00=400
    P00.01=0
    P00.04=400
    P00.05=400
    P00.06=110%
    P00.07=140
    P00.08=35%
    P00.09=120
    P00.10=30%
    P01.00=1
    P01.03=100%
    P01.04=110%
    P01.08=110%
    P03.08=120
    P03.09=400
    P0700=400
    P07.08=0
    P11.01=220
    P11.02=9
    P11.03=400
    P12.00=9
    P12.01=220
    P12.02=2
    P12.03=6.5
    P12.05=10
    P12.06=220
    Thank you mactec54!
    2.2kw 400hz air-cooled
    YL620-A VFD garage build
    Jul 2019
    Thank you mactec54!
    Hi mactec54. Thank you for the help so far. Im still having issues setting up the yl620-a. Youve forwarded me some initial settings...but when i got to parameter 1101 im only able to enter a value from 0-3, but your initial settings want me to input 220?
    Have i done something wrong, or might there be an error in the initial settins list?
    Im running it 220v with a 2.2kw air-cooled spindle.
    I think i should do a factory reset to be sure the parameters are correctly entered before i go any farther.
    Pls help me reset and replace the parameters...
    Jan 2005
    You should not have to do a reset just post where you have a problem and I may be able to help, there manuals are not very good at explaining the different fuctions
    You may find some of these can be left as 0= not activated ( 1 ) 110v ( 2 ) 220 ( 3 ) 380v
    Your model has 0 / 1 / 2 / 3 for some of the Parameter settings if not sure just leave it at 0 which is deactivated
    Mactec54
    Jul 2019
    Thank you sir!
  7. #7
    Member hafizi5299's Avatar
    Sep 2018
    Hye there..
    Just wanna know, do u still need help for the parameter 620a?
  8. #8
    Jul 2019
    hello hafizi5299...still not complete unfortunately, havent powered it all up yet, i will post when its closer...
  9. #9
    Member peedeevee's Avatar
    Oct 2019
    I found this thread googling around for help with my recent YL620-A purchase. I'm trying to figure out how to do the equivalent of 'RUN' and 'STOP' from remote. Any help would be much appreciated.
