Hello Dears,
need I to use power EMI filter for 3-phase 400V FULING VFD inverter 5.5KW, ? And if so can you give me some advises what model should it be
You have to know how many amps the Motor /Spindle you are driving and then you can work out what you need, most look up what the max input current is for the VFD Drive and then size the Filter to suit that
Mactec54
