16/3 @ 18 AMP per conductor - for VFC Cable ?
Results 1 to 11 of 11
Thread: 16/3 @ 18 AMP per conductor - for VFC Cable ?
    Jul 2013
    Default 16/3 @ 18 AMP per conductor - for VFC Cable ?
    Hi guys,
    Is the max AMP a spindle will draw distributed along the 3 wires? or per wire?
    I ask because I bough a 14/3 wire and it is huge (thick), however I see some folks using and selling a 16/3 VDF Cable which will be much thinner and manageable.
    Thank you.
    Jan 2005
    Default Re: 16/3 @ 18 AMP per conductor - for VFC Cable ?
    All 3 wires will have 18 amps. However, 16/3 VFD cable exposed to air in open tray has max 18 amp capacity. Chances of running at 18 amps max is probably nill and you can restrict amps by setting 17 amps as max in VFD.
    Jul 2013
    My question is, if my spindle draws 15 amps, it is going to pull 15 amp per each one of those 3 wires, not 5 amps each.
    Mar 2003
    Shelby Township
    Yes, 15 each.
    - - - Updated - - -
    What size spindle is this?
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
    Jan 2005
    Yes. 15 amps each wire but thats when you have set program to max out ipm to point where spindle is ready to stall and trip out. You most likely never will do that. you have answered your own question. A 16/3 vfd cable is good for 18 amps. If your spindle is 15 amps max you can use 16/3 not 14/3. Just make sure it's for VFD to Spindle shielded cable.
    Jul 2013
    Quote Originally Posted by ger21 View Post
    Yes, 15 each.
    - - - Updated - - -
    Quote Originally Posted by nwrepair1 View Post
    Ger thank you for clarifying. This is a 110V 2.2KW. so 20 Amps.
    (I looked into a "smaller spindle" but I like to be able to use a ER20 collet compatible cutter (1/2").
    With that said, I think I should be good with the 16 gauge at 18 amps. I did not know you could limit the amp draw in the VFD.
  7. #7
    May 2013
    washington
    2.2kw at 110vac 3 phase is only 11.5 amps. 16 gauge is fine.
    a vfd delivering 2.2kw from 120vac single phase (with a dumb rectifier and capacitor input filter) will draw as high as 30 amps rms from your 120vac single phase supply. you will probably never actually run your spindle that hard so you may get by with a 20 amp breaker on a 12 gauge wire.
    also these spindles are rated by the input vars, not watts. you may only be drawing a peak of 1800 watts from the outlet which is on the order of 25 amps rms
  8. #8
    Mar 2003
    Shelby Township
    Most people are using 220V spindles, which are usually rated at 8-10 amps.
  9. #9
    Jul 2013
    Thank you, that makes sense. The 14 gauge VFD cable I have is a monster... I will try the 16 gauge, I should be good.
    Does anyone know how to set the current limit on a HY VFD?
  10. #10
    Mar 2003
    Shelby Township
    It should be PD142.
    If you don't have all the settings correct, you could instantly damage your spindle or VFD.
  11. #11
    Jul 2013
    I will look into it. Thank you
