- Need Help!- Vibration loosening spindle grub screws
Hi, I have a small Chinese CNC however the grub screws holding the ER11A 5mm Collect Chuck Holder to the spindle shaft keep loosening under cutting vibration, no matter how tight they are.
I have filed a small grove on the spindle shaft (one side) to seat the screw tighter, but over time they continue to come loose.
Has any one have an answer? Thanks
- You may not post replies
- You may not edit your posts
Forum Rules
