Who makes a good one?? Tripp Lite?
Yes it did matter because that type of cable the wires will fracture with the up down of the Z Axes and would not take very long for this to happen, must be quality stranded wire with a high flex rating, it also would be a electrical code violation wire like that, it also matters enough to save your VFD Drive and Spindle as this could damage the VFD Drive if it has not already
You also need a EMI Power Filter on the input power side this goes before the VFD Drive 20A should work for you
Mactec54
I found a piece of cable that I purchased when I bought the VFD/spindle. I thought that it was a bit heavy and stiff so I never used it. Luckily I found it. It is a 10’ piece of Beldon VFD cable. I will be changing it out this week.
Mactec54
Cable diameter and weight was my first concern when I was first building my machine. . The beldon cable is fairly thick even at 16awg. What is the diameter of the Ingus cable?
While you are waiting for your cable here are some Parameters for you to try
Huanyang Mactec54
Spindle 1.5kW 220V 400Hz Air Cooled
PD000=0 for Parameter unlock ( 1 ) for Parameter Lock
PD001=0 (1 For Remote Control) ( 1 For 0-10v Terminal Control or Remote Trim Pot Control ) ( J1 Also Needs to be set for Terminal Control )
PD002=0
PD003=400
PD004=400
PD005=400
PD006=76
PD007=20
PD008=220 (Motor Rated Voltage)
PD009=33
PD010=11
PD011=120 ( Watch for over heating at this Temperature with this Parameter it may need to be increased if your Spindle is over heating at this Speed Air Cooled Spindles Only )
PD13= 08 ( is for Factory reset, Only use this to set VFD to Factory Default Settings )
PD014=8 ( Acceleration Adjust to suit)
PD015=8 ( Deceleration Adjust to suit)
PD141=220 ( Motor Rated Voltage )
PD041=6 ( Carrier Frequency max up to 10 )
PD142=7 ( Motor Max Amps for 1.5Kw Spindle)
PD143=2 ( Motor Number of Poles)
PD144=3000 (Max Motor RPM) =3,000= (24,000)
PD70=0 ( This may need to be set to 1 if Control Voltage is 0-5v )
PD72=400
PD73=120 ( Set to match PD011 )
PD120=120
PD174= (Set to Max VFD Drives Output Amp Rating )
Mactec54
You size the wire or cable size for the motor amps, not for if it fits in the connector! All you need to do is set a dust tight Junction box on the moving part of the Z carriage, run your proper size flex shielded cable to it, ground the ground wire to the metal Z frame and run a ground wire to the spindle motor bracket or motor its self. Then run a approved flex conduit to the connector for the spindle with the 3 wires for power inside to the motor.
1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
Once I get everything back together correctly and working, Is there a maximum size router bit that I should be using with a 1.5kw spindle?
I find myself using 1/4 inch shank, V bits from 1/4 to 1/2 inch diameter, 60 to 90 degree and 2 flute both flat and round nose milling bits. Or 1/2 inch shank of the same. I also have a few 3/8 inch diameter milling bits. Buy good collets, the cheap ones work are not accurate, and are difficult to work with. Ask me how I know!
I bought a decent set of collets online. Been using a 1/4” end mill. Seems to cut nicer than a ball end mill which really surprised me. I may try an 1/8” ball end mill. Since my machine is manual and not CNC, I have to make a matching stylus to trace an original pattern.
Get Techniks collets. While you're at it, get a Techniks collet nut. Techniks are pretty much the best available. I've never the collets sold in sets, however.
You didn't mention the brand of your "set of collets." If they are the typical Chinese set, they are probably so-so at best.
I bought 1/8, 1/4 and 1/2 in collets, which covers everything I do.
Gary
Mine are a chinese set. Since my machine isn’t meant to be precision, They work ok. This is something I always wanted to build . All hobby stuff, no production. Video in action....when it worked!
I found like Gary GME says the brand he mentions, and I had forgotten the name are far better. The cheap Chinese set I purchased it was difficult to get bits in and out of and yes they were US or Imperial not Metric.
so far the collets fit fine. Of course if I don't get this thing running right again it wont matter. SAE sizes are great for me.
I also have two new VFDS and replacement motor on stand by. I tried all the wiring and programming suggestions hear and it still over load faults. My neighbor an electrician says to call power company as my voltages still seem high
