Teco 7200MA VFD settings Help
Page 1 of 2 12 LastLast
Results 1 to 12 of 23
Thread: Teco 7200MA VFD settings Help
    Activation process JohnTC's Avatar
    Jan 2019
    Default Teco 7200MA VFD settings Help
    I have a Teco 7200MA VFD 240v 50/60hz. HP: 3 KVA: 4. output 3ph 240v 9.6amp
    the original spindle motor has died, I have decided to replace it with a water cooled spindle.
    I have bought a Jianken JDG 80/2.2kw 220v 400hz 6A water cooled spindle
    these are the VFD parameters sent with it
    power: 2.2kw
    max speed: 24000rpm
    upper limit of the frequency: 400HZ
    rated frequency: 400HZ
    time of speed up / down: 20~30s
    need help with the setup parameters any help would be greatly appreciated.
    I have the user manual for the VFD but find it very confusing I would like to get it right first time rather than damage the spindle or VFD
    Jan 2005
    Default Re: Teco 7200MA VFD settings Help
    Quote Originally Posted by JohnTC View Post
    power: 2.2kw
    max speed: 24000rpm
    Can you post a PDF of the manual I have some Teco VFD drive manuals but not that one yes you need more than just those parameters
    Mactec54
    Jan 2019
    here it is. thanks for taking time to help
    Attached Files Attached Files
    Jan 2005
    This should get you going there may be some other Parameters to adjust or set
    Teco 2.2Kw 400Hz 24000 RPM Spindle
    BN-01=6 ( Acceleration Adjustable )
    Bn-02=8 ( Deceleration Adjustable )
    CN-02=400
    CN-03=220
    CN-04=400
    CN-05=200
    CN-06=110
    CN-07=120
    CN-08=66
    CN-09=8
    CN-10=50
    CN-19=30
    CN-25=110
    CN-26=110
    CN-34=4 ( Adjust up to 6 )
    CN-45=2400
    CN-46=02
    SN-66=1 ( Auto Tune after all Parameters are set )
    Mactec54
    Jan 2019
    Many Thanks Mactec54
    Jan 2019
    Im getting an PG parameter Error with the above settings
    "Quote from manual"
    Cn-45 and Cn-46 must meet the following relationship:
    2 * Cn-45 * Cn-02 / Cn-46
    ?If not, an error message “Input Error” will be displayed
    Help
  7. #7
    Jun 2017
    Your error is due to incorrect parameters.....the calculation the drive made with the parameters you were given is causing this error
  8. #8
    Jan 2019
    thx for reply. yes I realise that. its the Cn-45 parameter that's the problem.
  9. #9
    Jan 2005
    "Quote from manual"
    Help
    That's the spindle RPM
    The CN46=2 for your 2 Pole motor
    CN02=400 which is correct
    So CN-46 has to match the spindle RPM 24000 I'm not sure if it can accept 24000
    So CN-46=24000 Not 2400 should correct this
    Mactec54
  10. #10
    Jan 2005
    Quote Originally Posted by ericks View Post
    The parameters are correct unless you know better
    CN-2=400
    CN-46=2 number of Poles
    CN-45=24000 spindle speed
    CN-45=2400 missing a 0
    Mactec54
  11. #11
    Sep 2005
    CN-2=400
    Yes you posted it wrong
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
  12. #12
    Jan 2019
    well I have a problem. the Cn-45 parameter range is 0000.1 ~ 3000.0 P/R. is there a work around.
