Teco 7200MA VFD settings Help - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
Thread: Teco 7200MA VFD settings Help
  1. #21
    Member mactec54's Avatar
    Jan 2005
    Default Re: Teco 7200MA VFD settings Help
    Quote Originally Posted by JohnTC View Post
    I have contacted the makers first before posting and they haven't got back to me
    Cn-45 parameter looks to be for encoder counts per revolution, I maybe wrong still learning
    Which you don't have to set so leave it at the default CN-45=0.0 and you should be set
    Mactec54
  2. #22
    Sep 2005
    This is the correct as a Snip right out of the PDF as you can clearly see the default is 0.1 not 0.0
    Attached Thumbnails Attached Thumbnails Teco 7200MA VFD settings Help-screen-shot-2019-05-23-4-36-a
    1000x750 Workbee CNC - Mach4 - PMDX USB - Windows 10 Pro
  3. #23
    ericks
    Guest
    To the op.... If you still need assistance then i will be available later to help you... But you need to be with your drive so we can go through the settings
