Ground question on 2.2 kw water cooled spindle
Results 1 to 3 of 3
Thread: Ground question on 2.2 kw water cooled spindle
    Activation process cncneon's Avatar
    Aug 2018
    Default Ground question on 2.2 kw water cooled spindle
    My 2.2 pin #4 has continuity with nothing. From what I've researched its probably an unconnected ground. Don't want to pull the back off this
    rt now so I'm wondering - will I be OK just grounding the spindle case or mount block?
    Thanks to all
    cncneon
    Sep 2005
    Default Re: Ground question on 2.2 kw water cooled spindle
    Quote Originally Posted by cncneon View Post
    Thanks to all
    cncneon
    There should be a ground wire in your 4 wire feed to the spindle power, just ground to it. All thats required is you ground to the metal on the spindle. You can not depend on the Z axis being 100% grounded at all times.
    Retired Master Electrician, HVAC/R Commercial. FLA Saturn 2 4x4 CNC Router Mach4 Kimber 1911 45ACP
    Member john-100's Avatar
    Mar 2007
    uk
    from another post here on cnczone a photo of an added earth connection inside a spindle
    Ground question on 2.2 kw water cooled spindle-adding-earth-connection-jpg
    at best the chinese are very lax with the earthing on their products
    and do not reserve the green/yellow wires for earth/ground connections !!!
    also don't use the same cable colour code through out
    the photos of one 6040 machine I used to trace the wiring had the stepper motor wires change colour twice
    the cable had different colours to the motor and the wiring inside the cnc control box was different again
    wiring for one machine
    Ground question on 2.2 kw water cooled spindle-6040-tx14207-tb6560-stepper-driver-wiring-jpg
    Ground question on 2.2 kw water cooled spindle-control-box-wiring-2-jpg
    Ground question on 2.2 kw water cooled spindle-6040-controlbox-vfd-wiring-jpg
    another machine had used different colour cables !
    I suspect they use the cheapest cable available when the machine is made
    and different manufacturers make their own version of what looks like the same machine
    John
    PS
    To avoid opening the spindle motor
    I would have a look to see if you can use one of the 4 screws that fastens the end on the motor or the 4 screws that fastens the connector to attach an earth wire to the motor
