is Vietnam the new China for cheap ATC spindles?
Results 1 to 4 of 4
Thread: is Vietnam the new China for cheap ATC spindles?
    Mar 2017
    Default is Vietnam the new China for cheap ATC spindles?
    Has anyone here been brave enough to try one of the lower cost ATC spindles from Vietnam that recently appeared on ebay?
    https://www.ebay.com/itm/CNC-mill-sp...MAAOSwWylckmI~
    $1300 for a 5.5kw ATC spindle seems like a good deal. I wonder how good they are...
    Mar 2018
    Default Re: is Vietnam the new China for cheap ATC spindles?
    Look at these, they also seem very good and same style
    Jingjiang City Jianken High-Speed Electricmotor Co., Ltd.
    Jan 2005
    Quote Originally Posted by Goemon View Post
    They look the same as what is from China so may be just a reseller, there is also a problem with that spindle when they do the tool change video the spindle itself is moving forward which is a problem this should not move forward when they do a tool change
    Mactec54
    Mar 2017
    The tool change capability is the only reason why anyone would consider one so if there is an issue with that then they are a waste of time. Shame.
    Still, they are a good bit cheaper than what is being sold from China. It would be odd if a reseller in a different country was able to offer such a discount over local sellers. Maybe it's a sign of the times. China is on the up so they are outsourcing production to Vietnam.
