hello I hope it helps you I have a problem I think that configuration vdf I do not know how to configure
Voltaje nominal del husillo 220 Voltios
Here are 2 lots of Parameters see what your VFD Drive has and set which ever Parameters your VFD Drive has
Mactec54 1.5Kw
XSY-ATI 200X
P01=400
P05=100
P06=400
P07=100
P26=400
AT1-2200XSY
P00=220
P01=400
P03=15 ( adjust up to 25 )
P04=220
P05=100
P06=400
P07=100
P10=1 Default Potentiometer control ( 2 ) External Control
P011=0 Default Key Board Control ( 1 ) External Control
P025=0 2Pole
P034= 10 ( adjust Acceleration )
P042=10 ( adjust Deceleration )
P078= ??? ( Max Amp Overload set to suit your spindle )
P069= Over Voltage 220/240
Mactec54
thank you, thank you now I hope it works well
hello me testing parameters but it does not work, but it instantly jumps err 1
this model
Check your wiring especially the spindle plug it is saying you have a short circuit, or current overload
Check the spindle windings with a meter , post a photo of your wiring
Pin1 to Pin2
Pin2 to Pin3
Pin3 to Pin1
Pin4 to Earth /Ground ( Spindle Body )
Check these Parameters there may be some others these are slightly different from the other manual, there manual is not very good I have 3 different manuals for the same VFD Drive so very confusing VFD Drive, I would not recommend anyone to buy this VFD Drive
P00=220
P01=400
P02=110
P03=25
P04=20
P05=400
P06=400
P07=100
P21=24000
P26=400
P34=400
P69=230
Mactec54
well, it looks like I'm going from bad to worse, hehe but keep trying
for a future I buy another variator to recommend
this is what happens now
spindle connection & xsy-at1 I think well
ok now I do not have shielded cable
Buy and test I hope it works
thanks for the help you are giving me
I'm testing xsy-at1 disconnected from the spindle
It works well
connected spindl err 3
I hope today I can acquire protected cable
P004 = 220 does not let rise more than 220
P069 = 240 err3
I keep trying to see if there is luck
Mactec54
I do not understand what happens it's all very strange
P069 = 400 works fine but everything without spindle
but if P069 220 gives error 3 instantly
do not spindle
with spindle
The VFD is also not displaying the correct output at full turn of the pot should be=400 so is not working correct
The VFD Drive is saying you have a short circuit
Either the wiring from the VFD to the Spindle
Or the Spindle is Faulty have you checked with a meter
Pin1 to Pin2= ??
Pin2 to Pin3= ??
P3 to Pin1 = ??
Pin4 to Spindle Body =
And check all Pins to the spindle body
If you can't do this you need to have it tested at a motor repair shop
Mactec54
I think I have got
P01 =400
P02=220
P03=200
P04=0000
P05=0000
P06=400
P07=0000
Does not sound very good you need the minimum frequency setting at P05=100 this is to protect the spindle
See what P20 is set at this may help with the frequency noise you may have to go higher or lower with that Parameter just watch the temperature if you go up higher this will change how it sounds
Mactec54
