Mactec54
I ended up ordered a TDK-Lambda #RSEN-2030 yesterday from Mouser.
Should I stop worrying about the unusual noises the spindle makes. Other than the strange noise the spindle runs and cuts fine. The noise this spindle is making is not very loud,no where near as loud as the last spindle.
I am assuming since I already bumped the carrier frequency to 10 that there isn't any other parameters to change.
Yes I thought it was a good price also.Should be here Tuesday
The sound starts out as a lower frequency sound at 6000 RPM and increases in frequency as the speed increases. At about 19000 you can hardly hear it anymore. Here is another video from 6000 to 24000 rpm.
https://photos.app.goo.gl/QSAXg3Daq8r2gPUBA
Hey mactec54 if you get a few minutes please take a look at my latest video in the last post and let me know what you think. I have two more days before my 30 day return period is up with Amazon so If I need to exchange anything it will be much easier.
Thanks for the help
Mactec54
I think I will run with the way it is since it really doesn't sound that bad. The power filter is coming today so I will get that installed.
Thanks for the help
PD007 is the Starting Frequency for ramping up to speed
The Intermediate parameter's are related to the torque of the motor being driven, PD006 and PD009 are related and can be adjust while running, if one is adjusted the other needs to be also to keep the V/F ratio correct
Mactec54
